Inleiding
If you aren't able to adjust the AM/FM channel on your radio, the tuning dial may not be working. In just a few minutes, though, you can get it replaced!
It's important not to mix this up with the volume dial, as they are unique components and will not be interchangable.
Wat je nodig hebt
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
Unplug the socket connection from the motherboard as shown in the image.
