Ga door naar hoofdinhoud
Eton FRX3 Rechargeable Battery Pack Replacement
  1. Eton FRX3 Rechargeable Battery Pack Replacement, Rechargeable Battery Pack: stap 1, afbeelding 1 van 1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Rechargeable Battery Pack Replacement: stap 2, afbeelding 1 van 1
    • Disconnect the battery pack wires from the device and remove the battery pack.
Conclusie
To reassemble your device, follow these instructions in the reverse order.
3 andere personen hebben deze handleiding voltooid.
Kenneth Sills
762 Reputatie
6 handleidingen geschreven
USF Tampa, Team 1-6, Nance Spring 2016 Lid van USF Tampa, Team 1-6, Nance Spring 2016
USFT-NANCE-S16S1G6
4 Leden
13 handleidingen geschreven
4 opmerkingen
My question is where can you find an FRX3 replacement battery?
jalwitt - Antwoord
Hey mate, you can buy the battery packs from a number of sources. Here's the link to one of those sources https://www.amazon.com/HQRP-FR200-BAT-3A...
james -
is it ok to replace it with a higher capacity lithium battery?
troydeleon - Antwoord
As long as the specifications match, that should be fine. Just be careful when swapping out components in circuits, as it can potentially destroy the device if they're incompatible!
Kenneth Sills -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 33
Altijd: 5,289
