Ga door naar hoofdinhoud
Eton FRX3 Case Assembly Disassembly
Wat je nodig hebt
  1. Eton FRX3 Case Assembly Disassembly, Rechargeable Battery Pack: stap 1, afbeelding 1 van 1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Case Assembly Disassembly: stap 2, afbeelding 1 van 1
    • Disconnect the battery pack wires from the device and remove the battery pack.
  3. Eton FRX3 Case Assembly Disassembly, Case Assembly: stap 3, afbeelding 1 van 1
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
  4. Eton FRX3 Case Assembly Disassembly: stap 4, afbeelding 1 van 1
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
  5. Eton FRX3 Case Assembly Disassembly: stap 5, afbeelding 1 van 1
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
  6. Eton FRX3 Case Assembly Disassembly: stap 6, afbeelding 1 van 1
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
  7. Eton FRX3 Case Assembly Disassembly: stap 7, afbeelding 1 van 1
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
Conclusie
To reassemble your device, follow these instructions in the reverse order.
james
2.213 Reputatie
2 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.535 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 400
