Inleiding
If your AM Radio is not receiving signal, then you may be in a deadzone or it might be broken. If it is damaged, you will need to follow this guide to replace it.
Wat je nodig hebt
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
Remove the six Phillips #0, 1 cm screws that secure the motherboard to the case.
To reassemble your device, follow these instructions in the reverse order.
