Inleiding
This guide will teach you how to access the motherboard in order to replace the Ethernet ports.
Wat je nodig hebt
Remove the antennas by unscrewing them from the base.
Flip over the device and locate the four rubber feet on the bottom.
Remove the rubber feet with tweezers
Locate the Ethernet ports
Flip the motherboard and locate the 40 solder points corresponding to the Ethernet ports
Melt the 40 solder points using a soldering gun.
6 andere personen hebben deze handleiding voltooid.
Één opmerking
Can you make a guide to replace the antenna base connector, mine get broken at the base, I wonder if it is possible to make the cable connection directly to the antenna, does that could work?
