Ga door naar hoofdinhoud
Ethernet Diagnostics Port
Wat je nodig hebt
    • The ethernet diagnostics port is located behind the drivers side instrument panel cover.
    • The plastic panel is secured by 3 metal flex trim clips. Using an appropriate pry tool pry backwards at the points indicated
    • After opening the side panel, hold onto the cover until you disconnect the key fob antenna connector. Failure to do so could cause excessive strain on the wiring
    • Reach into the opening to feel for the diagnostic cable, if you have never had the car serivced it may be tucked down into the recess
    • There should only be one cable with a circular white connector
    • Pull out the connector, but be careful, since there is not much slack in the cable. This is part of a large and expensive wiring harness.
    • Connect the FakraHSD to Ethernet cable until you hear a click.
    • To disconnect press down on the small finger and gently pull the connectors apart.
Conclusie
obrien28
553 Reputatie
2 handleidingen geschreven
iMaster Repairs Lid van iMaster Repairs
Business
1 Lid
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 708
