Ga door naar hoofdinhoud
Etekcity Lasergrip 1080 Motherboard Replacement
Wat je nodig hebt
  1. Etekcity Lasergrip 1080 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Motherboard Replacement: stap 3, afbeelding 1 van 2 Etekcity Lasergrip 1080 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Motherboard Replacement, Buttons: stap 4, afbeelding 1 van 2 Etekcity Lasergrip 1080 Motherboard Replacement, Buttons: stap 4, afbeelding 2 van 2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Motherboard Replacement: stap 5, afbeelding 1 van 2 Etekcity Lasergrip 1080 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Motherboard Replacement: stap 7, afbeelding 1 van 2 Etekcity Lasergrip 1080 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Motherboard Replacement, Etekcity Lasergrip 1080 Trigger Replacement: stap 9, afbeelding 1 van 2 Etekcity Lasergrip 1080 Motherboard Replacement, Etekcity Lasergrip 1080 Trigger Replacement: stap 9, afbeelding 2 van 2
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Etekcity Lasergrip 1080 Motherboard Replacement, Laser: stap 10, afbeelding 1 van 1
    • Pull the motherboard out of its slot in the device.
  11. Etekcity Lasergrip 1080 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Use a soldering iron to melt the solder that holds the wires for the laser to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
  12. Etekcity Lasergrip 1080 Motherboard Replacement, Sensor: stap 12, afbeelding 1 van 1
  13. Etekcity Lasergrip 1080 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Using a soldering iron, melt the solder that holds the wires for the sensor to the motherboard.
  14. Etekcity Lasergrip 1080 Motherboard Replacement, Battery Connector: stap 14, afbeelding 1 van 1
  15. Etekcity Lasergrip 1080 Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Use a soldering iron and melt the solder where the battery connector's wires are attached to the motherboard.
  16. Etekcity Lasergrip 1080 Motherboard Replacement, Screen: stap 16, afbeelding 1 van 1
    • Carefully pull the motherboard out of its slot in the body of the device.
  17. Etekcity Lasergrip 1080 Motherboard Replacement: stap 17, afbeelding 1 van 2 Etekcity Lasergrip 1080 Motherboard Replacement: stap 17, afbeelding 2 van 2
    • Unscrew the two 3.4 mm screws on the motherboard.
  18. Etekcity Lasergrip 1080 Motherboard Replacement: stap 18, afbeelding 1 van 1
    • Take off the cover and separate the parts.
    • All of these parts are fragile and mishandling them may cause damage.
Conclusie
Patrick Crawford
741 Reputatie
6 handleidingen geschreven
USF Tampa, Team 5-1, Blackwell Fall 2015 Lid van USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 434
