Ga door naar hoofdinhoud
Etekcity Lasergrip 1080 Button Replacement
Wat je nodig hebt
  1. Etekcity Lasergrip 1080 Button Replacement, Battery: stap 1, afbeelding 1 van 1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Button Replacement: stap 2, afbeelding 1 van 1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Button Replacement: stap 3, afbeelding 1 van 2 Etekcity Lasergrip 1080 Button Replacement: stap 3, afbeelding 2 van 2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Button Replacement, Buttons: stap 4, afbeelding 1 van 2 Etekcity Lasergrip 1080 Button Replacement, Buttons: stap 4, afbeelding 2 van 2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Button Replacement: stap 5, afbeelding 1 van 2 Etekcity Lasergrip 1080 Button Replacement: stap 5, afbeelding 2 van 2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Button Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Button Replacement: stap 7, afbeelding 1 van 2 Etekcity Lasergrip 1080 Button Replacement: stap 7, afbeelding 2 van 2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Button Replacement: stap 8, afbeelding 1 van 1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
Conclusie
Patrick Crawford
741 Reputatie
6 handleidingen geschreven
USF Tampa, Team 5-1, Blackwell Fall 2015 Lid van USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 460
