Ga door naar hoofdinhoud
Inleiding
This guide will show you how to replace the battery connector. This replacement is necessary if a new battery is installed and the device still won't work or if the wires break. This will use a screwdriver and a soldering iron. Be careful when using the soldering iron as it is very hot. There is a link to a soldering guide in the Troubleshooting section of the device page.
  1. Pull the battery cover away from the handle by gripping near the thumb groove.
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Gently pull the battery out of the handle.
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Disconnect the battery by pulling the connector away from it. Positive first
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Remove the battery cover from the device by pulling it straight out. Remove the battery cover from the device by pulling it straight out.
    • Remove the battery cover from the device by pulling it straight out.
  5. Using the plastic opening tool remove the front and rear yellow covers. When removing the back cover, be careful not to lose the buttons as they are not connected.
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Remove the two 3.1 mm Phillips #0 screws.
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Pull the two halves apart. Be careful not to lose any components on the inside.
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Realign the buttons with the button terminals.
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Carefully pull the trigger out. The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Pull the motherboard out of its slot in the device.
    • Pull the motherboard out of its slot in the device.
  11. Use a soldering iron and melt the solder where the battery connector's wires are attached to the motherboard.
    • Use a soldering iron and melt the solder where the battery connector's wires are attached to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
Conclusie
Patrick Crawford
741 Reputatie
6 handleidingen geschreven
USF Tampa, Team 5-1, Blackwell Fall 2015 Lid van USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
3 Leden
9 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 457
