Inleiding
Are the buttons on your Escort Radar 9500IX's cracked or jammed? If this is the case, then follow this guide to replace the buttons on your radar.
Wat je nodig hebt
Carefully pry the grey frame off the black plastic covering using the nylon spudger.
Bijna klaar!
Conclusie
Één opmerking
Ummm where/how do you get the replacement buttons. Mine are just simply non legible from wear and tear, yet still works perfectly.
