Inleiding
This guide explains how to replace the buttons on the Epson VS240. The buttons control many functions of the device, and if one or more have stopped functioning, it may be necessary to replace them. Special requirements include a Phillips #1 screwdriver and having a gentle touch, because the piece you'll be fixing is very delicate.
Power down and unplug the projector before beginning.
Wat je nodig hebt
Using the Phillips #2 screwdriver, loosen the single captive screw on the left side of the projector.
Slide the panel off and remove it from the device.
Gently disconnect the white ribbon cable connecting the motherboard to the button panel.
