Ga door naar hoofdinhoud
Epson Stylus Photo 1400 Printhead Replacement
Wat je nodig hebt
  1. Epson Stylus Photo 1400 Printhead Replacement, Housing: stap 1, afbeelding 1 van 1
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Printhead Replacement: stap 2, afbeelding 1 van 2 Epson Stylus Photo 1400 Printhead Replacement: stap 2, afbeelding 2 van 2
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
  3. Epson Stylus Photo 1400 Printhead Replacement: stap 3, afbeelding 1 van 2 Epson Stylus Photo 1400 Printhead Replacement: stap 3, afbeelding 2 van 2
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Printhead Replacement: stap 4, afbeelding 1 van 2 Epson Stylus Photo 1400 Printhead Replacement: stap 4, afbeelding 2 van 2
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Printhead Replacement: stap 5, afbeelding 1 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 5, afbeelding 2 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 5, afbeelding 3 van 3
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Printhead Replacement: stap 6, afbeelding 1 van 2 Epson Stylus Photo 1400 Printhead Replacement: stap 6, afbeelding 2 van 2
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Printhead Replacement: stap 7, afbeelding 1 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 7, afbeelding 2 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 7, afbeelding 3 van 3
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Printhead Replacement: stap 8, afbeelding 1 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 8, afbeelding 2 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 8, afbeelding 3 van 3
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Printhead Replacement: stap 9, afbeelding 1 van 2 Epson Stylus Photo 1400 Printhead Replacement: stap 9, afbeelding 2 van 2
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Printhead Replacement: stap 10, afbeelding 1 van 2 Epson Stylus Photo 1400 Printhead Replacement: stap 10, afbeelding 2 van 2
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Printhead Replacement: stap 11, afbeelding 1 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 11, afbeelding 2 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 11, afbeelding 3 van 3
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Printhead Replacement: stap 12, afbeelding 1 van 2 Epson Stylus Photo 1400 Printhead Replacement: stap 12, afbeelding 2 van 2
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
  13. Epson Stylus Photo 1400 Printhead Replacement, Printhead: stap 13, afbeelding 1 van 2 Epson Stylus Photo 1400 Printhead Replacement, Printhead: stap 13, afbeelding 2 van 2
    • Insert a flathead screwdriver into the hole on the right side of the frame.
    • Turn the screwdriver counterclockwise until it stops.
  14. Epson Stylus Photo 1400 Printhead Replacement: stap 14, afbeelding 1 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 14, afbeelding 2 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 14, afbeelding 3 van 3
    • Move the carriage unit to the center.
  15. Epson Stylus Photo 1400 Printhead Replacement: stap 15, afbeelding 1 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 15, afbeelding 2 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 15, afbeelding 3 van 3
    • Open the cartridge cover.
    • Remove all the ink cartridges inside.
  16. Epson Stylus Photo 1400 Printhead Replacement: stap 16, afbeelding 1 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 16, afbeelding 2 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 16, afbeelding 3 van 3
    • Using a plastic opening tool, disengage the two upper tab on the side of the carriage unit.
    • With a spudger or plastic opening tool, disengage the lower tab.
  17. Epson Stylus Photo 1400 Printhead Replacement: stap 17, afbeelding 1 van 2 Epson Stylus Photo 1400 Printhead Replacement: stap 17, afbeelding 2 van 2
    • Slide the cover upward and rotate it around the hinge by 90°.
  18. Epson Stylus Photo 1400 Printhead Replacement: stap 18, afbeelding 1 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 18, afbeelding 2 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 18, afbeelding 3 van 3
    • The CSIC assembly sits inside the carriage unit.
    • Reaching from the back of the carriage unit, disengage the two tabs that hold the CSIC assembly in place.
    • The tabs can be difficult to disengage. The second image shows the rear of CSIC assembly.
    • The third image shows where the tabs lock onto the carriage unit.
    • Remove the CSIC assembly from the carriage unit.
  19. Epson Stylus Photo 1400 Printhead Replacement: stap 19, afbeelding 1 van 2 Epson Stylus Photo 1400 Printhead Replacement: stap 19, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using tweezers, disengage the right tab from the back right panel of the carriage unit.
    • Push the tweezers towards the front of the printer while pulling up on the right panel.
    • When the tab is disengaged, you can pull the panel upwards slightly to prevent the tab from engaging.
  20. Epson Stylus Photo 1400 Printhead Replacement: stap 20, afbeelding 1 van 1
    • Using the tweezers, disengage the left tab from the back left.
    • Push the tweezers towards the front of the printer while pulling on the left side upwards.
    • When both tabs are disengaged, the part is slightly raised.
  21. Epson Stylus Photo 1400 Printhead Replacement: stap 21, afbeelding 1 van 2 Epson Stylus Photo 1400 Printhead Replacement: stap 21, afbeelding 2 van 2
    • Lift CSIC assembly up and out of the Carriage Unit.
  22. Epson Stylus Photo 1400 Printhead Replacement: stap 22, afbeelding 1 van 1
    • The printhead is the part with 6 nozzles.
    • Remove the three 8 mm #2 Phillips screws that secure the printhead.
  23. Epson Stylus Photo 1400 Printhead Replacement: stap 23, afbeelding 1 van 2 Epson Stylus Photo 1400 Printhead Replacement: stap 23, afbeelding 2 van 2
    • Remove the printhead from the carriage unit by lifting it up vertically.
  24. Epson Stylus Photo 1400 Printhead Replacement: stap 24, afbeelding 1 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 24, afbeelding 2 van 3 Epson Stylus Photo 1400 Printhead Replacement: stap 24, afbeelding 3 van 3
    • Disconnect the two ribbon cables on the back of the printhead.
Conclusie
20 andere personen hebben deze handleiding voltooid.
Larry Huang
1.004 Reputatie
4 handleidingen geschreven
Cal Poly, Team 17-11, Regan Fall 2011 Lid van Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Leden
12 handleidingen geschreven
16 opmerkingen
Dear Larry,
Thank you for your excellent, thorough guide.
Since all I am replacing is the printhead, why do I need to remove the covers from the printer? In the later steps, you show clearly how to remove the printhead directly from the top front of the printer. Isn't that all I have to do to remove and replace the printhead?
After replacing the printhead on the Epson 1400, do I need to do some special kind of reset?
Thanks very much for your help and attention.
CalFox - Antwoord
By default, the cartridge box is on the right most side of the printer. To get the printhead out, you need to disengage two tabs on the back of the cartridge box, shown on step 18. It's impossible to get to the right side one unless you can move the cartridge box close to the middle. And by default, you can't move the cartridge box by hand unless you unlock it on step 13, which is inside the side housing. If you can get away with sticking your hand inside the small rectangular hole of the top housing, then you don't have to take it off. But it's very difficult to maneuver your tweezers without lots of room. It's a tricky and awkward motion for your hand to disengage it, so we took off the housing first.
I'm not sure if any resets need to be done. You might have to realign the printhead using the printer software after you install it if the prints turn out strange.
Larry Huang -
With a simple hooked-end machinists scribe, it was easy to gently lift each little tab forward from the front and then easily lift the back board (over the printhead screws) straight up.
All I needed to do to let the printhead be moveable is turn the unit off, then turn it on. The printhead moves to center, then unplug the unit. Now the printhead is easy to move.
This "unplug it" method is common to most CISS retrofits to most Epson printers and it is not supposed to hurt anything.
Jon
CalFox - Antwoord
I think Calfox is right - just turn printer on, then unplug as carriage starts to move. Then it can be moved freely.
Also a 4 - 5 mm Allen key can be used to unhook the CSIC plate - place angled end of key behind carriage, & feel for the edge of the clip. Then pull forward on allen key, & up on the CSIC plate. Do both sides. Take care not to damage the encoder strip.
Will try scribe method next -
Stuart - Antwoord
So, I have the Epson Photo Stylus 1400 too. Mine was in storage for almost a year. When I tried to use it again, it didn't recognize that there was any ink in the cartridges. I replaced the cartridges and still didn't recognize that there was ink in the cartridges. I tried to clean it from the maintenance menu, but no luck. Any ideas on what I can do?
Jason cLYBURN - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 132
Altijd: 44,008
