Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Open cover of the printer.
Open the cartridge cover by pressing down on the tab and lifting it up.
Grab the sides of the ink cartridge and pull it out.
Replace ink cartridge with brand new ink cartridge.
5 opmerkingen
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
