Ga door naar hoofdinhoud
Epson Stylus Photo 1400 Ink cartridge replacement
Wat je nodig hebt
  1. Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: stap 1, afbeelding 1 van 2 Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: stap 1, afbeelding 2 van 2
    • Open cover of the printer.
    • Open the cartridge cover by pressing down on the tab and lifting it up.
  2. Epson Stylus Photo 1400 Ink cartridge replacement: stap 2, afbeelding 1 van 2 Epson Stylus Photo 1400 Ink cartridge replacement: stap 2, afbeelding 2 van 2
    • Grab the sides of the ink cartridge and pull it out.
    • Replace ink cartridge with brand new ink cartridge.
  3. Epson Stylus Photo 1400 Ink cartridge replacement: stap 3, afbeelding 1 van 2 Epson Stylus Photo 1400 Ink cartridge replacement: stap 3, afbeelding 2 van 2
    • Close cartridge cover.
    • Close cover of the printer.
Conclusie
Larry Huang
1.004 Reputatie
4 handleidingen geschreven
Cal Poly, Team 17-11, Regan Fall 2011 Lid van Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Leden
12 handleidingen geschreven
5 opmerkingen
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - Antwoord
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - Antwoord
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - Antwoord
Poor instructions on how to get ink cartridge holder in right position.
rpttrsn - Antwoord
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
joe waldroff - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 10,067
