Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Epson Stylus Photo 1400 Housing Replacement
Wat je nodig hebt
  1. Epson Stylus Photo 1400 Housing Replacement, Housing: stap 1, afbeelding 1 van 1
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Housing Replacement: stap 2, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 2, afbeelding 2 van 2
    • Locate the IEEE cover in the back.
    • Gently slide cover to the right to unlatch then pull to remove it.
  3. Epson Stylus Photo 1400 Housing Replacement: stap 3, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 3, afbeelding 2 van 2
    • Using a #2 Phillips screwdriver, remove the four 10mm screws shown.
    • Remove the 6mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Housing Replacement: stap 4, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 4, afbeelding 2 van 2
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Housing Replacement: stap 5, afbeelding 1 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 5, afbeelding 2 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 5, afbeelding 3 van 3
    • Insert the flathead screwdriver or plastic pry tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Housing Replacement: stap 6, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 6, afbeelding 2 van 2
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Housing Replacement: stap 7, afbeelding 1 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 7, afbeelding 2 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 7, afbeelding 3 van 3
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Housing Replacement: stap 8, afbeelding 1 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 8, afbeelding 2 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 8, afbeelding 3 van 3
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Housing Replacement: stap 9, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 9, afbeelding 2 van 2
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Housing Replacement: stap 10, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 10, afbeelding 2 van 2
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Housing Replacement: stap 11, afbeelding 1 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 11, afbeelding 2 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 11, afbeelding 3 van 3
    • Disconnect the cable on the side by carefully pulling it outwards.
    • You may need to gently rock the cable up and down while pulling.
  12. Epson Stylus Photo 1400 Housing Replacement: stap 12, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 12, afbeelding 2 van 2
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Larry Huang
1.004 Reputatie
4 handleidingen geschreven
Cal Poly, Team 17-11, Regan Fall 2011 Lid van Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Leden
12 handleidingen geschreven
Één opmerking
Thank you so much, Larry! I am repurposing my 1400 for sublimation printing and need to get the print head a little easier than standard methods! Much appreciated!
ryan Caputo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 7,541
