Ga door naar hoofdinhoud
Epson Stylus Photo 1400 Housing Replacement
Wat je nodig hebt
  1. Epson Stylus Photo 1400 Housing Replacement, Housing: stap 1, afbeelding 1 van 1
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Housing Replacement: stap 2, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 2, afbeelding 2 van 2
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
    errore avevo chiesto informazioni x sostituire la batteria al cellulare HUAWEI Mod. LX1
    Luigi Martinenghi - Antwoord
    avevo chiesto informazioni x la sostituzione della batteria cellulare HUAWEI Mod.LX1
  3. Epson Stylus Photo 1400 Housing Replacement: stap 3, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 3, afbeelding 2 van 2
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Housing Replacement: stap 4, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 4, afbeelding 2 van 2
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Housing Replacement: stap 5, afbeelding 1 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 5, afbeelding 2 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 5, afbeelding 3 van 3
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Housing Replacement: stap 6, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 6, afbeelding 2 van 2
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Housing Replacement: stap 7, afbeelding 1 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 7, afbeelding 2 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 7, afbeelding 3 van 3
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Housing Replacement: stap 8, afbeelding 1 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 8, afbeelding 2 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 8, afbeelding 3 van 3
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Housing Replacement: stap 9, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 9, afbeelding 2 van 2
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Housing Replacement: stap 10, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 10, afbeelding 2 van 2
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Housing Replacement: stap 11, afbeelding 1 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 11, afbeelding 2 van 3 Epson Stylus Photo 1400 Housing Replacement: stap 11, afbeelding 3 van 3
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Housing Replacement: stap 12, afbeelding 1 van 2 Epson Stylus Photo 1400 Housing Replacement: stap 12, afbeelding 2 van 2
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
    this is where I get stuck. the top won't come off. it seems to be stuck at the right front corner, where the buttons are. Is the button grouping part of the upper housing or does it come separate from the upper housing unit. The picture appears that you are taking the button attachment as part of the upper housing unit. But it is really stuck there on my 1400.
    1gr8nana - Antwoord
Conclusie
10 andere personen hebben deze handleiding voltooid.
Larry Huang
1.004 Reputatie
4 handleidingen geschreven
Cal Poly, Team 17-11, Regan Fall 2011 Lid van Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Leden
12 handleidingen geschreven
Één opmerking
Thank you so much, Larry! I am repurposing my 1400 for sublimation printing and need to get the print head a little easier than standard methods! Much appreciated!
ryan Caputo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 7,544
