Ga door naar hoofdinhoud
Epson Stylus NX230 Motherboard Replacement
Wat je nodig hebt
  1. Epson Stylus NX230 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Check to make sure the printer is unplugged to prevent electric shock.
  2. Epson Stylus NX230 Motherboard Replacement: stap 2, afbeelding 1 van 2 Epson Stylus NX230 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Align your printer so that the front buttons face to the right.
    • Remove the 3mm Phillips #2 screw in the hole in the top left corner. This screw attaches the side panel to the printer.
    • Store the screws in a safe place so you can access them later.
  3. Epson Stylus NX230 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Flip and remove the top of the printer up so that you can see the inside.
    • There is a white strip in the top right corner of the printer called the ribbon cable.
    • Make sure that the ribbon cable does not detach from the printer to prevent damaging the connection.
  4. Epson Stylus NX230 Motherboard Replacement: stap 4, afbeelding 1 van 2 Epson Stylus NX230 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Align the printer so the front button panel faces to the right.
    • Remove the 3mm Phillips #2 screw on the side of the printer in the top left corner.
    • Store the screw in a safe place so you can access it later.
  5. Epson Stylus NX230 Motherboard Replacement: stap 5, afbeelding 1 van 2 Epson Stylus NX230 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Take the right side of the bar of plastic that runs across the top of the inside of the printer and push it towards the left side of the printer.
    • Take the left side of the bar and push it to the left and then to the right.
  6. Epson Stylus NX230 Motherboard Replacement: stap 6, afbeelding 1 van 3 Epson Stylus NX230 Motherboard Replacement: stap 6, afbeelding 2 van 3 Epson Stylus NX230 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Using your hands, detach the side panel from the printer.
    • Take extra care with the locking mechanisms, which help keep the side panel on the printer.
    • You may need to use the plastic opening tools to pry apart the locking mechanisms.
  7. Epson Stylus NX230 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 3mm Phillips #2 screws attaching motherboard to the printer.
    • The motherboard can now be removed from the printer.
Conclusie
Kimberly Pugel
404 Reputatie
3 handleidingen geschreven
Cal Poly, Team 6-1, Forte Spring 2014 Lid van Cal Poly, Team 6-1, Forte Spring 2014
CPSU-FORTE-S14S6G1
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 7
Altijd: 1,231
