Inleiding
This is a replacement guide for the lamp for the Epson PowerLite 822 Plus. Model number EMP-822H. When the lamp is not working as it should that is when the projector image will become dim. This guide will show you how to remove and replace the current lamp in your projector.
Wat je nodig hebt
If you just used the projector you will want to let it sit for about an hour to cool off.
If you have not used the projector within the past few hours you are ready to get to work.
