Ga door naar hoofdinhoud
Epson Home Cinema 2150 Repair Power Supply Unit Replacement
Wat je nodig hebt
  1. Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Projector Lamp: stap 1, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Projector Lamp: stap 1, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Projector Lamp: stap 1, afbeelding 3 van 3
    • Disconnect and cool the device to room temperature. Failure to do so may result in electric shock or minor burns.
    • Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
    • Unscrew the single 6mm Phillips#2 holding screw from the access panel.
    • Slide the panel horizontally, then lift up to remove the access panel.
  2. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 2, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 2, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 2, afbeelding 3 van 3
    • Loosen and remove the two screws holding the lamp.
    • Remove two 9 mm Phillips #2 screws.
  3. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 3, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 3, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 3, afbeelding 3 van 3
    • Using four fingers, pull upwards on the lamp's plastic casing.
    • You may feel some resistance when pulling the lamp.
  4. Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Wireless connection board: stap 4, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Wireless connection board: stap 4, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Wireless connection board: stap 4, afbeelding 3 van 3
    • Remove the air filter cover. Grip the piece with two fingers above and below at the center.
    • Grab the air filter from the protruding tab and pull the filter out.
  5. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 5, afbeelding 1 van 2 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 5, afbeelding 2 van 2
    • From the back of the projector remove three 6 mm Phillips #1 screws.
  6. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 6, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 6, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 6, afbeelding 3 van 3
    • From the device's underside, remove eleven 9.5 mm Phillips #1 screws.
    • Remove two 6 mm Phillips #1 screws.
    • Pull off remaining plastic molding.
  7. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 7, afbeelding 1 van 2 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 7, afbeelding 2 van 2
    • From the lamp access slot, remove four 9.5 mm Philips #1 screws
  8. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 8, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 8, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 8, afbeelding 3 van 3
    • From the filter slot, unscrew two 9.5 mm #1 screws.
  9. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 9, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 9, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 9, afbeelding 3 van 3
    • Partially lift the top portion of the device housing.
    • Lifting too far or too hard may damage any cables between the housing and the motherboard.
  10. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 10, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 10, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 10, afbeelding 3 van 3
    • Disconnect the ribbon cable from the motherboard.
    • Ribbon cables are delicate. To avoid unnecessary stress to the cable, pull on the cable with the flat surface of two fingers.
  11. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 11, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 11, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 11, afbeelding 3 van 3
    • Remove three 5 mm Phillips #1 screws.
  12. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 12, afbeelding 1 van 2 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 12, afbeelding 2 van 2
    • Press on the metal connector and firmly pull on the remaining ribbon cable.
  13. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 13, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 13, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 13, afbeelding 3 van 3
    • Pull the clips on the case with two fingers on opposite ends and remove the case.
  14. Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Speaker: stap 14, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Speaker: stap 14, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Speaker: stap 14, afbeelding 3 van 3
    • Pull up on the rear panel retaining clip.
    • Pull the rear panel away from the device to remove.
  15. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 15, afbeelding 1 van 2 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 15, afbeelding 2 van 2
    • Disconnect the speaker wire from the motherboard.
    • Pull up at the end of the wire when removing the connector.
  16. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 16, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 16, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 16, afbeelding 3 van 3
    • Unwind the speaker wire through the metal chassis.
  17. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 17, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 17, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 17, afbeelding 3 van 3
    • Remove two 6mm Phillips #1 screws.
    • The speaker will fall out once screws are removed.
  18. Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Exhaust Fan: stap 18, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Exhaust Fan: stap 18, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Exhaust Fan: stap 18, afbeelding 3 van 3
    • Remove two 5 mm Phillips #1 screws.
  19. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 19, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 19, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 19, afbeelding 3 van 3
    • Disconnect a total of 10 motherboard connections.
    • Disconnect wires individually to avoid potential damage to the motherboard or the wires.
  20. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 20, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 20, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 20, afbeelding 3 van 3
    • Press on the metal connector and firmly pull to remove the remaining ribbon cable.
  21. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 21, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 21, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 21, afbeelding 3 van 3
    • Remove twelve 5 mm Phillips #1 screws.
    • Using both hands, carefully lift the first half of the motherboard.
  22. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 22, afbeelding 1 van 2 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 22, afbeelding 2 van 2
    • Disconnect the three brown ribbon connectors from the board.
    • Ribbon cables are delicate. To avoid unnecessary stress to the cable, pull on the cable with the flat surface of a finger.
    • Remove four 5 mm Phillips #1 screws.
    • Remove two 3 mm Phillips #1 screws.
    • Pull upwards on the motherboard to remove it from the projector.
  23. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 23, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 23, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 23, afbeelding 3 van 3
    • Remove the 7.5 mm Phillips #1 screw.
    • Set the black plastic lens sliders to the side.
  24. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 24, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 24, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 24, afbeelding 3 van 3
    • Remove five 9.5 mm Phillips #1 screws.
    • Remove one 6.0 mm Phillips #2 screw.
    • This screw is located to the right of the rear 9.5 mm screw.
    • Remove the metal bracket by pulling upwards on its sides.
  25. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 25, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 25, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 25, afbeelding 3 van 3
    • Remove the 9.5 mm Phillips #1 screw located behind the power supply.
    • Unwind the fan cable from the power supply for better access to the screw.
    • Remove the 10 mm Phillips #1 screw.
  26. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 26, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 26, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 26, afbeelding 3 van 3
    • Move the fan cable to the side for clear access to the sensor below it.
    • Using pliers, pull upwards on the white sensor to remove it from the fan assembly.
  27. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 27, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 27, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 27, afbeelding 3 van 3
    • Remove two 9.5mm Phillips #1 screws.
  28. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 28, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 28, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 28, afbeelding 3 van 3
    • Carefully lift upwards on the fan assembly to remove the fan from the projector.
  29. Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Power Supply Unit: stap 29, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Power Supply Unit: stap 29, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement, Power Supply Unit: stap 29, afbeelding 3 van 3
    • The power supply unit is a black box. Inside, there are two connected circuit boards, each with a single connector.
    • Using needle nose pliers, disconnect the first white connection cable from the circuit board.
    • Power suppl units have components that can hold an electric charge. Avoid touching anything other than the connector to avoid the risk of electric shock.
  30. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 30, afbeelding 1 van 2 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 30, afbeelding 2 van 2
    • From the rear side of the power supply unit, remove a single 9.5 mm Phillips #1 screw.
  31. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 31, afbeelding 1 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 31, afbeelding 2 van 3 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 31, afbeelding 3 van 3
    • Carefully lift the power supply unit 2-3 inches upwards without creating tension on the remaining wires.
    • Angle the power supply unit to the side for clear access to the remaining connector.
    • Using needle nose pliers, disconnect the remaining wires from the power supply connector.
  32. Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 32, afbeelding 1 van 2 Epson Home Cinema 2150 Repair Power Supply Unit Replacement: stap 32, afbeelding 2 van 2
    • Remove the power supply unit.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jose Vazquez
209 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 6-2, Adachi Fall 2022 Lid van CSU Los Angeles, Team 6-2, Adachi Fall 2022
CSULA-ADACHI-F22S6G2
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 1,196
