Ga door naar hoofdinhoud
Epson EH-TW9100 Disassembly & Cleaning
Wat je nodig hebt
  1. Epson EH-TW9100 Disassembly & Cleaning, The Problem: stap 1, afbeelding 1 van 1
    • Here you can see the green stain I got on the projection. It is caused by dust (in my case) on the green lcd panel. It is to a certain degree possible to focus the projector on these stains.
  2. Epson EH-TW9100 Disassembly & Cleaning, preparations: stap 2, afbeelding 1 van 1
    • Remove filter and lamp.
  3. Epson EH-TW9100 Disassembly & Cleaning: stap 3, afbeelding 1 van 2 Epson EH-TW9100 Disassembly & Cleaning: stap 3, afbeelding 2 van 2
    • Remove 10 non metric screws, one inside the lamp housing and 9 at the bottom. I marked all non metric screws with pink markers.
  4. Epson EH-TW9100 Disassembly & Cleaning: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • You can take of the front now. I used a guitar pick and a plastic card. Insert the pick carefully in the left side of the projector between case and front plate and try to make your way to the middle. Do the same from the right side, the front cover should come off now.
  5. Epson EH-TW9100 Disassembly & Cleaning: stap 5, afbeelding 1 van 2 Epson EH-TW9100 Disassembly & Cleaning: stap 5, afbeelding 2 van 2
    • Remove the metric screws at the back, I marked them with yellow markers. The rear plate should come off than
  6. Epson EH-TW9100 Disassembly & Cleaning: stap 6, afbeelding 1 van 3 Epson EH-TW9100 Disassembly & Cleaning: stap 6, afbeelding 2 van 3 Epson EH-TW9100 Disassembly & Cleaning: stap 6, afbeelding 3 van 3
    • 3 more metric bolts need to be unscrewed (yellow markers).
  7. Epson EH-TW9100 Disassembly & Cleaning: stap 7, afbeelding 1 van 2 Epson EH-TW9100 Disassembly & Cleaning: stap 7, afbeelding 2 van 2
    • Lift up and remove the lid.
  8. Epson EH-TW9100 Disassembly & Cleaning, The cleaning: stap 8, afbeelding 1 van 3 Epson EH-TW9100 Disassembly & Cleaning, The cleaning: stap 8, afbeelding 2 van 3 Epson EH-TW9100 Disassembly & Cleaning, The cleaning: stap 8, afbeelding 3 van 3
    • You can see the LCD block below the pcb.
    • [optional] plug the lamp back in
    • CAUTION: The next step instructs you to plug in the device while the housing is off and the board is exposed. Be careful not to touch anything as it may pose an electrocution risk.
    • [optional] To get it running you need to overwrite the switch next to the lamp as you can see on the second picture. As soon as you plug the projector in there will be LIVE PARTS everywhere, continue with extreme caution!
    • Unplug the device and let it cool down! As pointed out by Peter Källgren (see comments) it is not wise to spray flamable gases onto hot or live parts!
    • You dont need to remove the pcb. Just use some clean and dry air to blow into the holes where the cable go through. If you use air or gas in cans, make sure to not freeze the panels! If you use a compressor make sure there is no oil or water in the air. Be careful with the nozzle, especially if it is made out of metall.
Conclusie
Tobias F
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 27
Altijd: 2,531
