Inleiding
The lamp is the most important part of the Epson Brightlink 450Wi; it allows the image to be projected onto the screen by shining a light through the LCD system. Without a working lamp, your device is essentially useless; so it is very important to make sure your lamp is properly working.
For such an important part, it is luckily a replacement that just about anyone can perform. In the event your lamp isn't working right or when in need of replacement, follow this guide.
Wat je nodig hebt
Rotate Projector so you are looking at the right corner, next to the white EPSON logo.
On the right side, begin to unscrew the 11 mm screw.
