Ga door naar hoofdinhoud
Epiphone ES-335 PRO Pickguard Replacement
Wat je nodig hebt
  1. Epiphone ES-335 PRO Pickguard Replacement, Pickguard: stap 1, afbeelding 1 van 1
    • Locate the screw closest to the neck of the guitar.
    • Use a phillips head #2 screwdriver to completely unscrew the 1.0 mm length screw.
    • Be sure to keep any screws together as you will use them again, unless the replacement pickguard has its own screws.
  2. Epiphone ES-335 PRO Pickguard Replacement: stap 2, afbeelding 1 van 2 Epiphone ES-335 PRO Pickguard Replacement: stap 2, afbeelding 2 van 2
    • Using a phillips head #2 screwdriver, completely unscrew the 1.0 mm length screw.
    • Gently lift the pickguard off the body of the guitar.
Conclusie
Michaih Ley Bayani
515 Reputatie
4 handleidingen geschreven
Één opmerking
very nice and simple demo, but where would you get a new pickguard, as Epiphone will not
supply them and other aftermarket guards will not fit.
peterattard1 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 64
Altijd: 4,682
