Inleiding
The batteries included in the packs are prone to failure and leaking. This guide will show you how to replace the batteries with better quality rechargeables.
Onderdelen
  1. Remove battery pack from the Wii Remote and locate the two screws between the batteries.  Remove these and put them asside. The batteries used by the factory are underpowered 600mAh rechargeables.  I highly recommend replacing them with at least 850mAh ones, the higher the better.
    • Remove battery pack from the Wii Remote and locate the two screws between the batteries. Remove these and put them asside.
    • The batteries used by the factory are underpowered 600mAh rechargeables. I highly recommend replacing them with at least 850mAh ones, the higher the better.
  2. Pull out the battery from the case.  It should slide out easily.
    • Pull out the battery from the case. It should slide out easily.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Using your fingernail or a small screwdriver, carefully separate the two halves of the battery casing.  These aren't glued and should separate with little effort.
    • Using your fingernail or a small screwdriver, carefully separate the two halves of the battery casing. These aren't glued and should separate with little effort.
  5. Remove the two batteries, noting their orientation.
    • Remove the two batteries, noting their orientation.
    • Clean up any leaking battery acid and/or corrosion.
    • Out of the dozen or so battery packs I have repaired, every single one had failed due to corrosion. This occurred even in units that were just a few months old.
  6. Once the contacts and compartment are clean, insert your new rechargeable batteries.
    • Once the contacts and compartment are clean, insert your new rechargeable batteries.
  7. Re-insert the screws.  The battery pack will only fit in one direction.
    • Re-insert the screws. The battery pack will only fit in one direction.
    • While you are at it, clean the outer contacts and bend them out a little. This can help eliminate remotes having poor battery life.
Conclusie
You should now have a working battery pack. Insert back into the Wii Remote and place on the charger. Allow it to get a good full initial charge in order to extend your battery life.
Enjoy your "non-reparable" repaired induction charging system.
6 andere personen hebben deze handleiding voltooid.
Arcane Scroll
737 Reputatie
2 handleidingen geschreven
Wow, that explains it. So many complaints about the energizer inductive batteries dying quickly. They take a product meant for two AA and replace it with two AAA's. Yep, that'll limit your playing time...
Mike Propp - Antwoord
Easy to do! Just waiting to see if it will charge. If not, it was worth the shot. Thank you!
martinlu82 - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 35
Afgelopen 30 Dagen: 191
Altijd: 17,767
