Ga door naar hoofdinhoud
Enagic Water Filter SD501 Platinum Filter Replacement
Wat je nodig hebt
  1. Enagic Water Filter SD501 Platinum Filter Replacement, Filter: stap 1, afbeelding 1 van 1
    • Turn off and unplug the machine before cleaning it.
    • Clean the machine with a damp cloth or paper towel.
    • Make sure nothing dirty will get in the machine during the process.
  2. Enagic Water Filter SD501 Platinum Filter Replacement: stap 2, afbeelding 1 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 2, afbeelding 2 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 2, afbeelding 3 van 3
    • Open the filter door by pushing the "Push" button.
  3. Enagic Water Filter SD501 Platinum Filter Replacement: stap 3, afbeelding 1 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 3, afbeelding 2 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 3, afbeelding 3 van 3
    • Turn the ring at the bottom of the filter to the left until you hear a "click".
  4. Enagic Water Filter SD501 Platinum Filter Replacement: stap 4, afbeelding 1 van 2 Enagic Water Filter SD501 Platinum Filter Replacement: stap 4, afbeelding 2 van 2
    • Remove the ring for now.
  5. Enagic Water Filter SD501 Platinum Filter Replacement: stap 5, afbeelding 1 van 2 Enagic Water Filter SD501 Platinum Filter Replacement: stap 5, afbeelding 2 van 2
    • Lift up the old filter and discard or recycle appropriately.
    • Some water might be dripping out from the bottom of it. Have a towel ready to clean it up.
  6. Enagic Water Filter SD501 Platinum Filter Replacement: stap 6, afbeelding 1 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 6, afbeelding 2 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 6, afbeelding 3 van 3
    • Remove the two black rubber rings.
    • They are NOT components of the machine. The new filter you have prepared should come with new ones.
  7. Enagic Water Filter SD501 Platinum Filter Replacement: stap 7, afbeelding 1 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 7, afbeelding 2 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 7, afbeelding 3 van 3
    • Put your new filter in it.
    • Make sure that the two holes match the two popped-out parts from the filter.
    • The one that is bigger should be on the middle and the smaller one should be on the side.
    • This filter should be the new one that you have prepared and NOT the one that is removed from Step 5.
  8. Enagic Water Filter SD501 Platinum Filter Replacement: stap 8, afbeelding 1 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 8, afbeelding 2 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 8, afbeelding 3 van 3
    • Put the ring component back in.
    • Turn it to your right until you hear a click.
    • Make sure it is successfully locked in.
  9. Enagic Water Filter SD501 Platinum Filter Replacement: stap 9, afbeelding 1 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 9, afbeelding 2 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 9, afbeelding 3 van 3
    • Turn the filter back on.
    • Press the "Reset Switch"
    • "FILTER RESET" should be shown on the display.
  10. Enagic Water Filter SD501 Platinum Filter Replacement: stap 10, afbeelding 1 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 10, afbeelding 2 van 3 Enagic Water Filter SD501 Platinum Filter Replacement: stap 10, afbeelding 3 van 3
    • Attach the filter door.
    • There are three holes to slide the door edge into.
    • And push the "push" button to close it.
Conclusie
To change another filter, simply just follow the instructions once more.
Één andere persoon heeft deze handleiding voltooid.
Edwin Ng
205 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 42
Altijd: 1,841
