Inleiding
The speaker, which provides high-quality audio for voice interactions, music playback, and other features, is a crucial part of the Enabot EBO SE. Speakers may face wear and tear or technological problems that compromise their performance over time. It could be time to replace the speaker on your Enabot EBO SE if you're experiencing audio issues or decreased sound quality. We will take you step-by-step through the replacement of the speaker in this tutorial to help the process go smoothly.
Wat je nodig hebt
Gently turn the robot upside down.
Place the robot on a stable surface to prevent it from rolling or falling.
Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
Use the iFixit opening tool or your fingernail to disconnect the cable by placing the edge underneath the gray tab.
Flip the tab up and pull the ribbon cable out.
Disconnect the red and blue wires from the daughterboard by using your finger nails to pull up on the connector to disconnect.
Use a Phillips #00 screwdriver to remove each 7.4 mm screw from either side of the speaker.
