Ga door naar hoofdinhoud
Ematic Genesis 2 Screen Replacement
Wat je nodig hebt
  1. Ematic Genesis 2 Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Ematic Genesis 2 Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Screen Replacement: stap 2, afbeelding 1 van 3 Ematic Genesis 2 Screen Replacement: stap 2, afbeelding 2 van 3 Ematic Genesis 2 Screen Replacement: stap 2, afbeelding 3 van 3
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Screen Replacement: stap 3, afbeelding 1 van 2 Ematic Genesis 2 Screen Replacement: stap 3, afbeelding 2 van 2
    • Remove the three screws surrounding the circuit board using the Phillips Head Screwdriver.
    • Remove the circuit board from the device by uncliping the copper flexible PCB ribbon cable from the circuit board.
  4. Ematic Genesis 2 Screen Replacement: stap 4, afbeelding 1 van 1
    • Use the Small Pointed Metal Spudger to separate the LED screen from the front screen by gently wedging the spudger between the screen and the device.
  5. Ematic Genesis 2 Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the glass from the front casing by using the metal spudger to break it free from the device. (It's held together by glue.)
    • Install the new screen.
Conclusie
Brandon Key
246 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 440
