Ga door naar hoofdinhoud
Ematic Genesis 2 Charging Port Replacement
Wat je nodig hebt
  1. Ematic Genesis 2 Charging Port Replacement, Charging Port: stap 1, afbeelding 1 van 2 Ematic Genesis 2 Charging Port Replacement, Charging Port: stap 1, afbeelding 2 van 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Charging Port Replacement: stap 2, afbeelding 1 van 3 Ematic Genesis 2 Charging Port Replacement: stap 2, afbeelding 2 van 3 Ematic Genesis 2 Charging Port Replacement: stap 2, afbeelding 3 van 3
    • Remove all four screws surrounding the battery with the Phillips head screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Charging Port Replacement: stap 3, afbeelding 1 van 2 Ematic Genesis 2 Charging Port Replacement: stap 3, afbeelding 2 van 2
    • Remove both screws on either side of the audio jack using the Philips head screwdriver.
    • Detach audio jack from device.
  4. Ematic Genesis 2 Charging Port Replacement: stap 4, afbeelding 1 van 2 Ematic Genesis 2 Charging Port Replacement: stap 4, afbeelding 2 van 2
    • Remove the 3 screws surrounding the circuit board using the Philips head screwdriver.
    • Carefully disconnect the circuit board from the device by detaching the copper flexible PCB ribbon cable.
  5. Ematic Genesis 2 Charging Port Replacement: stap 5, afbeelding 1 van 2 Ematic Genesis 2 Charging Port Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a soldering iron to heat the solder holding the charging port to the circuit board.
    • Remove the charging port from board using tweezers.
  6. Ematic Genesis 2 Charging Port Replacement: stap 6, afbeelding 1 van 1
    • Solder replacement port into place.
    • Make sure all connections match original.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 546
