Ga door naar hoofdinhoud
Ematic Genesis 2 Battery Replacement
Wat je nodig hebt
  1. Ematic Genesis 2 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Ematic Genesis 2 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Battery Replacement: stap 2, afbeelding 1 van 3 Ematic Genesis 2 Battery Replacement: stap 2, afbeelding 2 van 3 Ematic Genesis 2 Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Battery Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Desoldering Pump
    $3.99
    Koop
    • Carefully remove the solder that connects the battery wires to the device using the solder sucker tool and a soldering iron.
    • When using the soldering iron to heat the existing solder, do not damage the device or surrounding connections.
    • Once all solder is gone, remove the wires from the device to free the battery.
  4. Ematic Genesis 2 Battery Replacement: stap 4, afbeelding 1 van 1
    • Use the soldering iron to solder the wires from the new battery to the device.
    • The connections from the wires should go in order from left to right being white, black (negative), and red (positive), respectively.
Conclusie
Brandon Key
246 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 346
