Ga door naar hoofdinhoud
Ematic Genesis 2 Audio Jack Repair
Wat je nodig hebt
  1. Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: stap 1, afbeelding 1 van 2 Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: stap 1, afbeelding 2 van 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Audio Jack Repair: stap 2, afbeelding 1 van 3 Ematic Genesis 2 Audio Jack Repair: stap 2, afbeelding 2 van 3 Ematic Genesis 2 Audio Jack Repair: stap 2, afbeelding 3 van 3
    • Remove all four screws surrounding the battery with the screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Audio Jack Repair: stap 3, afbeelding 1 van 1
    • Remove the two screws that hold the audio jack in place. Carefully lift the audio jack out of the compartment.
    • Use compressed air or a Q-tip to gently clear out the dirt from the inside of the audio jack. This will help make sure future connections are clear.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 153
