Ga door naar hoofdinhoud
Ematic Funtab FTABXXX Battery Replacement
Wat je nodig hebt
  1. Ematic Funtab FTABXXX Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Ematic Funtab FTABXXX Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • First, be sure to power off the device.
    • Carefully pry open the device. Note the plastic tabs in the image that hold the device together.
  2. Ematic Funtab FTABXXX Battery Replacement: stap 2, afbeelding 1 van 1
    • Locate the battery. Generally located in the middle of the device.
  3. Ematic Funtab FTABXXX Battery Replacement: stap 3, afbeelding 1 van 2 Ematic Funtab FTABXXX Battery Replacement: stap 3, afbeelding 2 van 2
    • Carefully pry off the battery from the display screen. This will be slight difficult since the battery is held onto the back of the display by adhesive.
  4. Ematic Funtab FTABXXX Battery Replacement: stap 4, afbeelding 1 van 1
    • Locate the red and black wire that runs from the battery and to the motherboard. Note the location of the wires, and carefully remove the soldered wires.
  5. Ematic Funtab FTABXXX Battery Replacement: stap 5, afbeelding 1 van 1
    • Attach the new battery to the same location as the old battery via adhesive.
    • Then, carefully solder the red wire to the '+' symbol on the motherboard and the black wire to the '-' symbol.
  6. Ematic Funtab FTABXXX Battery Replacement: stap 6, afbeelding 1 van 1
    • Once the solder has cooled, snap the front and back bezels together. Be sure to charge the new battery.
Conclusie
Robert Zarobinski
269 Reputatie
2 handleidingen geschreven
USF Tampa, Team 6-3, Brown Winter 2015 Lid van USF Tampa, Team 6-3, Brown Winter 2015
USFT-BROWN-W15S6G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 373
