Ga door naar hoofdinhoud
Ematic FunTab 3 Camera Replacement
Wat je nodig hebt
  1. Ematic FunTab 3 Camera Replacement, Back Panel: stap 1, afbeelding 1 van 3 Ematic FunTab 3 Camera Replacement, Back Panel: stap 1, afbeelding 2 van 3 Ematic FunTab 3 Camera Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Camera Replacement: stap 2, afbeelding 1 van 1
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Camera Replacement, Camera: stap 3, afbeelding 1 van 2 Ematic FunTab 3 Camera Replacement, Camera: stap 3, afbeelding 2 van 2
    • Remove the black tape to reveal the wire ribbon connector.
  4. Ematic FunTab 3 Camera Replacement: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool to flip up the black retaining tab.
  5. Ematic FunTab 3 Camera Replacement: stap 5, afbeelding 1 van 2 Ematic FunTab 3 Camera Replacement: stap 5, afbeelding 2 van 2
    • Pull out the wire ribbon connected to the camera.
    • The camera is held in place by glue, so extra force may be required.
    • Remove the camera from the device.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
Conclusie
Amanda Davis
581 Reputatie
5 handleidingen geschreven
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Lid van UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 233
