Ga door naar hoofdinhoud
Ematic FunTab 3 Back Panel Replacement
Wat je nodig hebt
  1. Ematic FunTab 3 Back Panel  Replacement, Back Panel: stap 1, afbeelding 1 van 3 Ematic FunTab 3 Back Panel  Replacement, Back Panel: stap 1, afbeelding 2 van 3 Ematic FunTab 3 Back Panel  Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Back Panel  Replacement: stap 2, afbeelding 1 van 1
    • Pull the back panel away from the screen.
Conclusie
Harrison Lee
85 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Lid van UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Leden
12 handleidingen geschreven
1Gids Commentaar
Our funtab3 is not work because we want to work but Anything is not work. We see a tiny crack
Adelaida Lopez Arias - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 259
