Ga door naar hoofdinhoud
Eluktronics N850HK SSD Replacement
Wat je nodig hebt
  1. Eluktronics N850HK SSD Replacement, SSD: stap 1, afbeelding 1 van 3 Eluktronics N850HK SSD Replacement, SSD: stap 1, afbeelding 2 van 3 Eluktronics N850HK SSD Replacement, SSD: stap 1, afbeelding 3 van 3
    • Push both switch locks inward to unlock the battery from the bottom panel.
    • The switch on the left must be held in place.
    • Remove the battery from the back of the laptop.
  2. Eluktronics N850HK SSD Replacement: stap 2, afbeelding 1 van 2 Eluktronics N850HK SSD Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the twelve 4 mm screws from the bottom panel of the laptop.
  3. Eluktronics N850HK SSD Replacement: stap 3, afbeelding 1 van 2 Eluktronics N850HK SSD Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws located under where the battery usually rests.
    • Do not remove the two additional screws near the bottom screw. These are connected to the motherboard and do not need to be removed.
  4. Eluktronics N850HK SSD Replacement: stap 4, afbeelding 1 van 2 Eluktronics N850HK SSD Replacement: stap 4, afbeelding 2 van 2
    • Lift the back case off and identify the SSD in the lower right corner.
    • Although the chances of damage are low, it is important to be aware of static electricity in your surroundings when working a computer motherboard. Ground yourself or use an anti-static wrist strap.
  5. Eluktronics N850HK SSD Replacement: stap 5, afbeelding 1 van 3 Eluktronics N850HK SSD Replacement: stap 5, afbeelding 2 van 3 Eluktronics N850HK SSD Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove 3 mm screw securing the SSD.
    • The SSD will naturally lift by a few millimeters.
    • Carefully slide the SSD from the M.2 slot.
  6. Eluktronics N850HK SSD Replacement: stap 6, afbeelding 1 van 3 Eluktronics N850HK SSD Replacement: stap 6, afbeelding 2 van 3 Eluktronics N850HK SSD Replacement: stap 6, afbeelding 3 van 3
    • Use the ridges on the right side to align the SSD properly.
    • Slide the new SSD into the M.2 mounting slot.
    • Use the Phillips #00 screwdriver to replace the 3 mm screw that secures the SSD.
  7. Eluktronics N850HK SSD Replacement: stap 7, afbeelding 1 van 3 Eluktronics N850HK SSD Replacement: stap 7, afbeelding 2 van 3 Eluktronics N850HK SSD Replacement: stap 7, afbeelding 3 van 3
    • Reassemble by following the directions in reverse order.
Conclusie
Alternative models where this guide may still apply:
  • Eluktronics N857HK1
  • Eluktronics N850HP6
4 andere personen hebben deze handleiding voltooid.
Brandon Yuan
226 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 72
Afgelopen 30 dagen: 371
Altijd: 4,354
