Ga door naar hoofdinhoud
Element GC-1020 Screen Replacement
Wat je nodig hebt
  1. Element GC-1020 Screen  Replacement, Back Cover Replacement Guide: stap 1, afbeelding 1 van 1
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
  2. Element GC-1020 Screen  Replacement: stap 2, afbeelding 1 van 1
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
  3. Element GC-1020 Screen  Replacement, Screen: stap 3, afbeelding 1 van 1
    • Unscrew the bottom of left and right sides of the motherboard.
    • Notice these screws are slightly larger than the ones on the outside of the device.
  4. Element GC-1020 Screen  Replacement: stap 4, afbeelding 1 van 2 Element GC-1020 Screen  Replacement: stap 4, afbeelding 2 van 2
    • Carefully bend the plastic frame to remove the motherboard.
    • Be sure that the power button, stays attached to the outer frame, as moving the motherboard it may cause it to loosen.
  5. Element GC-1020 Screen  Replacement: stap 5, afbeelding 1 van 3 Element GC-1020 Screen  Replacement: stap 5, afbeelding 2 van 3 Element GC-1020 Screen  Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Detach the screen by disconnecting the thin piece of ribbon cable attached to the PCB (printed circuit board).
    • Use a pair of tweezers to carefully pull the ribbon from the circuit board.
    • Take care not to damage the ribbon, as you will need it intact to reattach your new screen.
  6. Element GC-1020 Screen  Replacement: stap 6, afbeelding 1 van 3 Element GC-1020 Screen  Replacement: stap 6, afbeelding 2 van 3 Element GC-1020 Screen  Replacement: stap 6, afbeelding 3 van 3
    • Carefully pry apart the screen from the frame of the device.
    • Separate the two by peeling away the thin plastic layer that makes up the screen of the device.
    • If done correctly, your detached screen will look like this.
Conclusie
Lashaun Noel
591 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 259
