Ga door naar hoofdinhoud
Elegoo Mars 3 Limit Switch Replacement
Wat je nodig hebt
  1. Elegoo Mars 3 Limit Switch Replacement, Remove the back screws: stap 1, afbeelding 1 van 1
    • Remove 6 screws.
    • 12.5mm self tapping screws with 2.0mm hex socket head
  2. Elegoo Mars 3 Limit Switch Replacement, Remove the back lid: stap 2, afbeelding 1 van 2 Elegoo Mars 3 Limit Switch Replacement, Remove the back lid: stap 2, afbeelding 2 van 2
    • Use a small flat-headed screwdriver, spudger, or similar to pry open the lid enough to be able to get a grip of it and pull straight back and then fold down.
    • The back of the lid has a PCB with cables connecting it to the motherboard inside the unit. While not particularly fragile, do take care so you do not damage the connectors.
  3. Elegoo Mars 3 Limit Switch Replacement, Unplug the cable for the limit switch: stap 3, afbeelding 1 van 1
    • In my case the replacement limit switch was delivered already connected to a cable. If you are only replacing the actual switch you can skip this step and instead unplug the opposing end on the switch itself later..
    • Remove the limit switch cable connector in the bottom right corner by pulling it straight out.
    • Be sure to pull the connector, and not the cables!
  4. Elegoo Mars 3 Limit Switch Replacement: stap 4, afbeelding 1 van 3 Elegoo Mars 3 Limit Switch Replacement: stap 4, afbeelding 2 van 3 Elegoo Mars 3 Limit Switch Replacement: stap 4, afbeelding 3 van 3
    • Remove the two screws securing the limit switch.
    • M4x7.5mm socket screw with 2.5mm hex socket head
    • Hold the limit switch in the lower end and pull it downwards.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Konrad Skeri Ekblad
520 Reputatie
3 handleidingen geschreven
2 opmerkingen
I've looked everywhere and can't seem to find a place to buy a replacement limit switch. Any suggestions?
johnathan cuda - Antwoord
I got my replacement directly from Elegoo support. Send them an email, they are very helpful.
Konrad Skeri Ekblad -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 39
Altijd: 1,045
