Inleiding
Use this guide if your USB devices like smartphones are not charging from the port in your electrohome EAAC475. Also, you can use this guide to replace the port with the new one.
Wat je nodig hebt
Remove the 10 mm Phillips #1 screw from the battery cover.
Remove the battery cover.
Remove the two 10 mm Phillips #1 screws from the bottom of the device.
Remove two 10 mm Phillips #1 screws from the back side of the device.
Locate the screw holding the USB circuit board in place.
Take a Philips head screwdriver and remove the 10 mm screw.
Één andere persoon heeft deze handleiding voltooid.
