Ga door naar hoofdinhoud
Electrohome EAAC475 Speaker Replacement
Wat je nodig hebt
  1. Electrohome EAAC475 Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Electrohome EAAC475 Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Speaker Replacement, Buttons: stap 3, afbeelding 1 van 2 Electrohome EAAC475 Speaker Replacement, Buttons: stap 3, afbeelding 2 van 2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 Speaker Replacement: stap 4, afbeelding 1 van 3 Electrohome EAAC475 Speaker Replacement: stap 4, afbeelding 2 van 3 Electrohome EAAC475 Speaker Replacement: stap 4, afbeelding 3 van 3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 Speaker Replacement: stap 5, afbeelding 1 van 2 Electrohome EAAC475 Speaker Replacement: stap 5, afbeelding 2 van 2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
  6. Electrohome EAAC475 Speaker Replacement, Speaker: stap 6, afbeelding 1 van 2 Electrohome EAAC475 Speaker Replacement, Speaker: stap 6, afbeelding 2 van 2
    • Carefully and slowly detach one side from another.
    • Make sure the opposite sides are not separated completely.
    • Locate the speaker the inside of the back piece of the device
  7. Electrohome EAAC475 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Use the flat side of the spudger to remove the glue around the speaker.
    • This glue will need replacing when putting back the speaker.
  8. Electrohome EAAC475 Speaker Replacement: stap 8, afbeelding 1 van 1
    • After removing all the glue around the speaker, slowly take out the speaker.
    • Be careful not to break anything surrounding the speaker while using the spudger since it is sharp.
  9. Electrohome EAAC475 Speaker Replacement: stap 9, afbeelding 1 van 1
    • Detach the wires on the speaker and replace them with new ones.
Conclusie
Ruolin Cai
273 Reputatie
2 handleidingen geschreven
IUPUI, Team 2-1, Harley Spring 2016 Lid van IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 381
