Ga door naar hoofdinhoud
Electric Wheelchair Battery Replacement
  1. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: stap 1, afbeelding 1 van 3 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: stap 1, afbeelding 2 van 3 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: stap 1, afbeelding 3 van 3
    • Locate the two batteries under the back of the wheelchair.
    • Pull the first battery pack to where you can reach the red battery connector.
    • Be careful, the batteries are heavy.
  2. Electric Wheelchair Battery Replacement: stap 2, afbeelding 1 van 2 Electric Wheelchair Battery Replacement: stap 2, afbeelding 2 van 2
    • Disconnect the red battery connectors by pulling them apart.
  3. Electric Wheelchair Battery Replacement: stap 3, afbeelding 1 van 2 Electric Wheelchair Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the first and second battery from the wheelchair.
  4. Electric Wheelchair Battery Replacement: stap 4, afbeelding 1 van 2 Electric Wheelchair Battery Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the black battery connectors by pulling them apart.
  5. Electric Wheelchair Battery Replacement: stap 5, afbeelding 1 van 3 Electric Wheelchair Battery Replacement: stap 5, afbeelding 2 van 3 Electric Wheelchair Battery Replacement: stap 5, afbeelding 3 van 3
    • One at a time, disconnect the clips holding each battery case closed.
    • Open each case to reveal the battery inside.
  6. Electric Wheelchair Battery Replacement: stap 6, afbeelding 1 van 3 Electric Wheelchair Battery Replacement: stap 6, afbeelding 2 van 3 Electric Wheelchair Battery Replacement: stap 6, afbeelding 3 van 3
    • Remove the old battery from each case.
    • Put one new battery into each plastic case the old batteries were removed from.
  7. Electric Wheelchair Battery Replacement: stap 7, afbeelding 1 van 1
    • Reattach the clips on each of the battery's protective casings.
  8. Electric Wheelchair Battery Replacement: stap 8, afbeelding 1 van 3 Electric Wheelchair Battery Replacement: stap 8, afbeelding 2 van 3 Electric Wheelchair Battery Replacement: stap 8, afbeelding 3 van 3
    • Place the first battery back into the holder under the wheelchair.
    • Make sure that it is pushed all the way to the front of the wheelchair.
    • Place the second battery back into the holder.
  9. Electric Wheelchair Battery Replacement: stap 9, afbeelding 1 van 3 Electric Wheelchair Battery Replacement: stap 9, afbeelding 2 van 3 Electric Wheelchair Battery Replacement: stap 9, afbeelding 3 van 3
    • Reconnect the black battery connectors.
    • Do not connect the red connectors until the black are connected.
    • Reconnect the red battery connectors.
    • Check that the chair turns on and is fully charged.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Paige Efting
159 Reputatie
1 Handleiding geschreven
Één opmerking
I greatly enjoyed reading your article :) Please continue publishing helpful topics like this. Regards, from <a href="http://www.scootersnchairs.com">Scooters 'N Chairs</a>.
Justin Lubomirsky - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 77
Altijd: 6,856
