Ga door naar hoofdinhoud
Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement
Wat je nodig hebt
  1. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement, Opening Your Device: stap 1, afbeelding 1 van 1
    • Power down your device.
    • Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
  2. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 2, afbeelding 1 van 3 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 2, afbeelding 2 van 3 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 2, afbeelding 3 van 3
    • Insert the plastic opening tool into the seam near the corner of the device.
    • Slowly slide the tool around the perimeter of the device, gradually prying up the screen.
    • It is normal to hear snaps as the spring clips holding the screen in place are released.
    • It is also normal to hear adhesive separating, as a small amount is used to help secure the screen.
  3. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 3, afbeelding 1 van 3 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 3, afbeelding 2 van 3 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 3, afbeelding 3 van 3
    • When the screen is free of all spring clips and adhesive, slowly open the device like a clam shell with the hinge being the left hand side of the device.
    • Do not completely separate the screen from the case by more than a few inches, as they are still connected by three orange ribbon cables.
    • Safely place the device back on the table by laying the screen face down.
    • There will be some slight overlapping of the back of the case over the screen.
  4. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 4, afbeelding 1 van 2 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the ribbon cable by placing a plastic opening tool under the black plastic tab that is on the opposite side of the port as the ribbon cable.
    • Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
  5. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 5, afbeelding 1 van 1
    • Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports.
    • Repeat the previous process to remove the other ribbon cable.
  6. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
    • The device that we wrote this guide for did not come with a battery, so we cannot include it in our own guide steps.
    • The battery is removed during all repairs to protect against short circuits, shocks, and internal damage to the device.
  7. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement, Internal Lock and Volume Button: stap 7, afbeelding 1 van 1
    • Orient your device so that the lock and volume buttons and the attached components are on the top left.
  8. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 8, afbeelding 1 van 2 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 8, afbeelding 2 van 2
    • Remove the two 2.5mm screws using a Phillips #00 screwdriver.
  9. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 9, afbeelding 1 van 3 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 9, afbeelding 2 van 3 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 9, afbeelding 3 van 3
    • Use tweezers to pull back the strip of black tape covering the connection between the electronic portion of the lock and volume buttons and the motherboard.
    • Push the black part out of the white part of the connection using tweezers.
  10. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 10, afbeelding 1 van 1
    • The electronic portion of the lock and volume buttons should now be free to move. Lift it gently using tweezers, and set it aside.
  11. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement, LED Chip: stap 11, afbeelding 1 van 2 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement, LED Chip: stap 11, afbeelding 2 van 2
    • With a Phillips #00 screwdriver, remove the one 3.8 mm screw in the LED chip. The LED chip is a small green chip (about 1 square centimeter) located at the top center of the device.
    • Gently remove the chip with a pair of precision tweezers by grabbing the chip from one side, being careful not to pinch on a black piece of hardware on the chip.
  12. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement, Front and Back Camera: stap 12, afbeelding 1 van 2 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement, Front and Back Camera: stap 12, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the six 2.5mm screws and set them aside.
  13. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 13, afbeelding 1 van 2 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 13, afbeelding 2 van 2
    • Using tweezers, pull the black part of the connection between the mother board and speakers out of the white part of the connection.
  14. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 14, afbeelding 1 van 3 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 14, afbeelding 2 van 3 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 14, afbeelding 3 van 3
    • Gently pull the side wall of the device outwards, while using your other hand to pull the component fully into the device.
    • The right side of the motherboard should now be free to move.
  15. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 15, afbeelding 1 van 2 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 15, afbeelding 2 van 2
    • Using one of your hands, gently pull the side wall of the device outwards, while using your other hand to pull the component fully into the device.
    • The left and right sides of the motherboard should now be free to move.
  16. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 16, afbeelding 1 van 2 Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 16, afbeelding 2 van 2
    • The motherboard will still be attached to the device by ribbon cables and tape located near the cameras. Gently pull the tape off the back of the mother board to release it.
    • Ignore the ribbon cables still attached to the mother board. Fold the mother board down towards the bottom of the device.
  17. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 17, afbeelding 1 van 1
    • Using tweezers, gently pull the left camera, which is the front facing camera, and small attached ribbon cable off the device and set them aside.
  18. Eee Pad Transformer Prime TF201 Front and Back Cameras Replacement: stap 18, afbeelding 1 van 1
    • Use tweezers to gently lift the right camera, which is the rear camera, out of the device and set it aside.
Conclusie
Elaina Ryan
435 Reputatie
4 handleidingen geschreven
Cal Poly, Team 10-1, Livingston SU 2016 Lid van Cal Poly, Team 10-1, Livingston SU 2016
CPSU-LIVINGSTON-SU16S10G1
1 Lid
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 552
