Ga door naar hoofdinhoud
Edwin the Duck Rubber Heart Power Button Replacement
Wat je nodig hebt
  1. Edwin the Duck Rubber Heart Power Button Replacement, Rubber Heart Power Button: stap 1, afbeelding 1 van 2 Edwin the Duck Rubber Heart Power Button Replacement, Rubber Heart Power Button: stap 1, afbeelding 2 van 2
    • Unscrew the four 9mm screws with a T8 bit
    • Remove the back plate off
  2. Edwin the Duck Rubber Heart Power Button Replacement: stap 2, afbeelding 1 van 2 Edwin the Duck Rubber Heart Power Button Replacement: stap 2, afbeelding 2 van 2
    • Carefully take off the rubber skin.
    • It's important to remember to be patient and not rush. You don't want to rip or damage the rubber skin in then resulting in not having a waterproof cover.
  3. Edwin the Duck Rubber Heart Power Button Replacement: stap 3, afbeelding 1 van 1
    • Using the J1 bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Rubber Heart Power Button Replacement: stap 4, afbeelding 1 van 2 Edwin the Duck Rubber Heart Power Button Replacement: stap 4, afbeelding 2 van 2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. Remember to open slowly.
  5. Edwin the Duck Rubber Heart Power Button Replacement: stap 5, afbeelding 1 van 2 Edwin the Duck Rubber Heart Power Button Replacement: stap 5, afbeelding 2 van 2
    • Using the plastic opening tool pull up the black tab up until it stops.
    • Be careful not to pull up the black tab too far up, otherwise the cable won't be secure anymore.
    • Pull up the white cable tab up slowly
  6. Edwin the Duck Rubber Heart Power Button Replacement: stap 6, afbeelding 1 van 2 Edwin the Duck Rubber Heart Power Button Replacement: stap 6, afbeelding 2 van 2
    • Use the J1 bit to unscrew all four 9 mm screws connected to the motherboard.
    • Use the J1 bit to unscrew both 9 mm screws attached to the white plastic plate
  7. Edwin the Duck Rubber Heart Power Button Replacement: stap 7, afbeelding 1 van 1
    • Lift up the motherboard and speaker and place it away and to the side like you see in the picture
  8. Edwin the Duck Rubber Heart Power Button Replacement: stap 8, afbeelding 1 van 2 Edwin the Duck Rubber Heart Power Button Replacement: stap 8, afbeelding 2 van 2
    • Unscrew the two black 9 mm screws by using the J1 bit.
    • Remove the damaged rubber heart button and replace with a new rubber heart button.
Conclusie
Michelle Montano
116 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G4, Rose Fall 2017 Lid van UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 733
