Ga door naar hoofdinhoud
Edwin the Duck Rubber Heart Power Button Replacement
Wat je nodig hebt
    1. Edwin the Duck Rubber Heart Power Button Replacement, Rubber Heart Power Button: stap 1, afbeelding 1 van 2 Edwin the Duck Rubber Heart Power Button Replacement, Rubber Heart Power Button: stap 1, afbeelding 2 van 2
      • Unscrew the four 9mm screws with a T8 bit
      • Remove the back plate off
      Vraag FixBot
      Voeg opmerking toe
    2. Edwin the Duck Rubber Heart Power Button Replacement: stap 2, afbeelding 1 van 2 Edwin the Duck Rubber Heart Power Button Replacement: stap 2, afbeelding 2 van 2
      • Carefully take off the rubber skin.
      • It's important to remember to be patient and not rush. You don't want to rip or damage the rubber skin in then resulting in not having a waterproof cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Edwin the Duck Rubber Heart Power Button Replacement: stap 3, afbeelding 1 van 1
      • Using the J1 bit, unscrew all six 9 mm screws that run along the border.
      Vraag FixBot
      Voeg opmerking toe
    4. Edwin the Duck Rubber Heart Power Button Replacement: stap 4, afbeelding 1 van 2 Edwin the Duck Rubber Heart Power Button Replacement: stap 4, afbeelding 2 van 2
      • Use the plastic opening tool to open the inside of the duck.
      • Be very careful when splitting the two halves apart. There are wires connecting to both sides. Remember to open slowly.
      Vraag FixBot
      Voeg opmerking toe
    5. Edwin the Duck Rubber Heart Power Button Replacement: stap 5, afbeelding 1 van 2 Edwin the Duck Rubber Heart Power Button Replacement: stap 5, afbeelding 2 van 2
      • Using the plastic opening tool pull up the black tab up until it stops.
      • Be careful not to pull up the black tab too far up, otherwise the cable won't be secure anymore.
      • Pull up the white cable tab up slowly
      Vraag FixBot
      Voeg opmerking toe
    6. Edwin the Duck Rubber Heart Power Button Replacement: stap 6, afbeelding 1 van 2 Edwin the Duck Rubber Heart Power Button Replacement: stap 6, afbeelding 2 van 2
      • Use the J1 bit to unscrew all four 9 mm screws connected to the motherboard.
      • Use the J1 bit to unscrew both 9 mm screws attached to the white plastic plate
      Vraag FixBot
      Voeg opmerking toe
    7. Edwin the Duck Rubber Heart Power Button Replacement: stap 7, afbeelding 1 van 1
      • Lift up the motherboard and speaker and place it away and to the side like you see in the picture
      Vraag FixBot
      Voeg opmerking toe
    8. Edwin the Duck Rubber Heart Power Button Replacement: stap 8, afbeelding 1 van 2 Edwin the Duck Rubber Heart Power Button Replacement: stap 8, afbeelding 2 van 2
      • Unscrew the two black 9 mm screws by using the J1 bit.
      • Remove the damaged rubber heart button and replace with a new rubber heart button.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Michelle Montano
116 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G4, Rose Fall 2017 Lid van UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 1,086
