Ga door naar hoofdinhoud
Ecovacs Deebot 900 Motherboard Replacement
Wat je nodig hebt
  1. Ecovacs Deebot 900 Motherboard Replacement, Front Bumper: stap 1, afbeelding 1 van 2 Ecovacs Deebot 900 Motherboard Replacement, Front Bumper: stap 1, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  2. Ecovacs Deebot 900 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the black strip on the bottom of the bumper.
  3. Ecovacs Deebot 900 Motherboard Replacement: stap 3, afbeelding 1 van 2 Ecovacs Deebot 900 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Carefully lift up the bumper untill it pops out of place.​
  4. Ecovacs Deebot 900 Motherboard Replacement: stap 4, afbeelding 1 van 2 Ecovacs Deebot 900 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  5. Ecovacs Deebot 900 Motherboard Replacement, Bottom Case: stap 5, afbeelding 1 van 2 Ecovacs Deebot 900 Motherboard Replacement, Bottom Case: stap 5, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  6. Ecovacs Deebot 900 Motherboard Replacement: stap 6, afbeelding 1 van 2 Ecovacs Deebot 900 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
  7. Ecovacs Deebot 900 Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
  8. Ecovacs Deebot 900 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Carefully remove the ribbon cables connected to the top of motherboard.
    • Keep track of where the cables connect to the motherboard.
  9. Ecovacs Deebot 900 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the last three ribbon cables on the underside of the motherboard.​
  10. Ecovacs Deebot 900 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Lift the motherboard out of the Deebot and remove it from the device.
Conclusie
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Any suggestions on purchase options?
Curtis Tyler - Antwoord
vakum ozmo 900,hidup terus mati,lampu led juga mati,switch masih posisi on
markus arif - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 52
Afgelopen 30 dagen: 182
Altijd: 7,166
