Ga door naar hoofdinhoud
Ecovacs Deebot 900 Front Bumper Replacement
Wat je nodig hebt
  1. Ecovacs Deebot 900 Front Bumper Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Front Bumper Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Front Bumper Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Front Bumper Replacement: stap 4, afbeelding 1 van 1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Front Bumper Replacement: stap 5, afbeelding 1 van 1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Front Bumper Replacement, Front Bumper: stap 6, afbeelding 1 van 2 Ecovacs Deebot 900 Front Bumper Replacement, Front Bumper: stap 6, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Front Bumper Replacement: stap 7, afbeelding 1 van 1
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Front Bumper Replacement: stap 8, afbeelding 1 van 2 Ecovacs Deebot 900 Front Bumper Replacement: stap 8, afbeelding 2 van 2
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Front Bumper Replacement: stap 9, afbeelding 1 van 2 Ecovacs Deebot 900 Front Bumper Replacement: stap 9, afbeelding 2 van 2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Where may I buy the front bumper assembly? I'm trying to replace one for a deebot 901 but the mfg tells me they don't see the part directly.
Chris Khacherian - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 202
Altijd: 9,725
