Ga door naar hoofdinhoud
Ecovacs Deebot 900 Battery Replacement
Wat je nodig hebt
  1. Ecovacs Deebot 900 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Battery Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Battery Replacement: stap 4, afbeelding 1 van 1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Battery Replacement: stap 5, afbeelding 1 van 1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
Conclusie
5 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Great guide except no information on where to actually FIND a battery for this thing
Chris Staley - Antwoord
Where can replacement battery packs be acquired from?
Larry Smith - Antwoord
You can find the battery at Taobao online shopping
Jimmy - Antwoord
Amazon also sells them. Make sure to get one for the correct model though (there are alot of them)
Kevin Dunn - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 97
Afgelopen 30 dagen: 446
Altijd: 22,161
