Ga door naar hoofdinhoud
Ecovacs DEEBOT D35 Vacuum Motor Replacement
Wat je nodig hebt
  1. Ecovacs DEEBOT D35 Vacuum Motor Replacement, Vacuum Motor: stap 1, afbeelding 1 van 1
    • Lay the Deebot face down so you have access to the battery compartment. Remove the battery.
  2. Ecovacs DEEBOT D35 Vacuum Motor Replacement: stap 2, afbeelding 1 van 1
    • Locate the 9 screws that secure the back cover. Remove with a PH2 Phillips Head Screwdriver. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Vacuum Motor Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger or plastic opening tool to separate the Deebot backside.
  4. Ecovacs DEEBOT D35 Vacuum Motor Replacement: stap 4, afbeelding 1 van 1
    • Carefully lift the back cover from the body of the Deebot to expose the internal wiring harnesses.
  5. Ecovacs DEEBOT D35 Vacuum Motor Replacement: stap 5, afbeelding 1 van 1
    • There are 5 wiring harnesses that need to be disconnected before completely removing the back cover.
    • There are two blue wiring harnesses on the front left and right side (located next to the sensor). They are represented by the red circles.
    • There is a multicolor wiring harness on the front center. This is represented by the orange circle.
    • Two black and red wiring harnesses are connected to the motherboard. This is represented by the yellow circles.
  6. Ecovacs DEEBOT D35 Vacuum Motor Replacement: stap 6, afbeelding 1 van 1
    • Locate the 4 screws on the vacuum motor.
  7. Ecovacs DEEBOT D35 Vacuum Motor Replacement: stap 7, afbeelding 1 van 1
    • Remove the screws from the vacuum motor body with a PH2 Phillips Head Screwdriver. The screws are:
    • 4 x 10mm screws
  8. Ecovacs DEEBOT D35 Vacuum Motor Replacement: stap 8, afbeelding 1 van 1
    • Remove the vacuum motor body
Conclusie
3 andere personen hebben deze handleiding voltooid.
Brian
475 Reputatie
3 handleidingen geschreven
USF Tampa, Team 12-2, Eyestone Spring 2017 Lid van USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
4 Leden
4 handleidingen geschreven
Één opmerking
thanks a lots for the valuable info
sk law - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 8,961
