Ga door naar hoofdinhoud
Ecovacs DEEBOT D35 Motherboard Replacement
Wat je nodig hebt
  1. Ecovacs DEEBOT D35 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Flip the D35 onto its back.
  2. Ecovacs DEEBOT D35 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the 9 screws with a PH2 Phillips screwdriver on the underside of the D35. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use spudger or plastic opening tool to separate the Deebot backside
  4. Ecovacs DEEBOT D35 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Carefully lift the back cover from the body of the Deebot
  5. Ecovacs DEEBOT D35 Motherboard Replacement: stap 5, afbeelding 1 van 2 Ecovacs DEEBOT D35 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • There are 5 cables that need to be carefully disconnected before completely disconnecting the back cover:
    • The 5 cables two blue cables on the front left and right side (located next to the sensor). Represented by the red arrows.
    • Multicolor ribbon in the front center. Represented by the blue arrow.
    • Two (black and red) two prong adapter connected to the motherboard. Represented by the green arrow.
  6. Ecovacs DEEBOT D35 Motherboard Replacement: stap 6, afbeelding 1 van 3 Ecovacs DEEBOT D35 Motherboard Replacement: stap 6, afbeelding 2 van 3 Ecovacs DEEBOT D35 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Locate the 3 screws on the motherboard:
    • 2 x 14mm screws
    • 1 x 10mm screws
  7. Ecovacs DEEBOT D35 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the screws from the motherboard with a PH2 Phillips Head Screwdriver. The screws are:
    • 2 x 14mm screws
    • 1 x 10mm screws
  8. Ecovacs DEEBOT D35 Motherboard Replacement: stap 8, afbeelding 1 van 2 Ecovacs DEEBOT D35 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Locate and disconnect 12 cables bundles connected on the motherboard
  9. Ecovacs DEEBOT D35 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Carefully disconnect the motherboard from the Deebot body.
Conclusie
Kevin McKernan
107 Reputatie
1 Handleiding geschreven
USF Tampa, Team 12-2, Eyestone Spring 2017 Lid van USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 2,721
