Ga door naar hoofdinhoud
Eco X Gear Battery Replacement
Wat je nodig hebt
  1. Eco X Gear Battery Replacement, Frame: stap 1, afbeelding 1 van 1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Battery Replacement: stap 3, afbeelding 1 van 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Battery Replacement: stap 4, afbeelding 1 van 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Disconnect the wiring to improve accessibility to the battery.
  6. Eco X Gear Battery Replacement: stap 6, afbeelding 1 van 2 Eco X Gear Battery Replacement: stap 6, afbeelding 2 van 2
    • Remove the two screws that hold that bracket, securing the battery in place.
  7. Eco X Gear Battery Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the wires that hold the batteries down to the motherboard.
  8. Eco X Gear Battery Replacement: stap 8, afbeelding 1 van 1
    • Pry the battery from the frame using your hands or an opening pick.
  9. Eco X Gear Battery Replacement: stap 9, afbeelding 1 van 1
    • When removing and installing the battery, be cautious to not damage any of the surrounding electronics.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
James Lipsett
625 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S9-G3, Martin Spring 2017 Lid van UMass Dartmouth, Team S9-G3, Martin Spring 2017
UMASSD-MARTIN-S17S9G3
2 Leden
3 opmerkingen
Where to get the new battery?
James Chen - Antwoord
Hello EcoXGear lovers, i just bought this battery from amazon yesterday and perfect fit with polarity you can get the battery here
https://www.amazon.com/gp/product/B08ZCQ...
partha - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 23
Altijd: 671
