Ga door naar hoofdinhoud
Eclipse MTE28VGM Lens Cover Replacement
Wat je nodig hebt
  1. Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: stap 1, afbeelding 1 van 3 Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: stap 1, afbeelding 2 van 3 Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: stap 1, afbeelding 3 van 3
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
  2. Eclipse MTE28VGM Lens Cover Replacement: stap 2, afbeelding 1 van 3 Eclipse MTE28VGM Lens Cover Replacement: stap 2, afbeelding 2 van 3 Eclipse MTE28VGM Lens Cover Replacement: stap 2, afbeelding 3 van 3
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
  3. Eclipse MTE28VGM Lens Cover Replacement: stap 3, afbeelding 1 van 2 Eclipse MTE28VGM Lens Cover Replacement: stap 3, afbeelding 2 van 2
    • Using the plastic spudger, pry the plastic lens cover off of the camera.
    • Attach the replacement plastic lens cover to the camera.
Conclusie
Tyler Hudgens
288 Reputatie
2 handleidingen geschreven
IUPUI, Team 2-1, Harley Fall 2016 Lid van IUPUI, Team 2-1, Harley Fall 2016
IUPUI-HARLEY-F16S2G1
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 180
