Ga door naar hoofdinhoud
Eclipse 180G2 Outer Case Replacement
Wat je nodig hebt
  1. Eclipse 180G2 Outer Case Replacement, Outer Case: stap 1, afbeelding 1 van 2 Eclipse 180G2 Outer Case Replacement, Outer Case: stap 1, afbeelding 2 van 2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: stap 2, afbeelding 1 van 3 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: stap 2, afbeelding 2 van 3 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: stap 2, afbeelding 3 van 3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jesse Minor
662 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-4, Tanski Winter 2015 Lid van USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 Leden
5 handleidingen geschreven
Één opmerking
What if there is no charge port or USB port there no longer?
May 303 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 1,339
