Ga door naar hoofdinhoud
Eclipse 180BL LCD Screen Cover Replacement
Wat je nodig hebt
  1. Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: stap 1, afbeelding 1 van 3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: stap 1, afbeelding 2 van 3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: stap 1, afbeelding 3 van 3
    • To start, remove the two screws located at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair ToolKit.
    • Both Screws are 1/8 inch in length.
    • Remove the case, and with the Spudger, apply force to the USB port to remove the inner component.
    • Be careful, as releasing the tension will cause all parts to become loose and separate.
  2. Eclipse 180BL LCD Screen Cover Replacement: stap 2, afbeelding 1 van 3 Eclipse 180BL LCD Screen Cover Replacement: stap 2, afbeelding 2 van 3 Eclipse 180BL LCD Screen Cover Replacement: stap 2, afbeelding 3 van 3
    • The LCD screen cover is placed into its slot after all the inner components are replaced.
    • Get the new screen cover, and carefully place in alignment with the outer shell.
    • Be sure that the screen fits perfectly, as dust getting in the screen will cause pixels to die.
Conclusie
Thomas Schwarz
499 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 543
